Part Number: 51742
UPC Number: 765809517424
Principal Application: Ford, IHC Trks w/6.9 Diesel Engine (83-93), 7.3L Diesel Engine (87-95)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.968
Outer Diameter Top: 4.282
Outer Diameter Bottom: Closed
Thread Size: 1 1/2-16
By-Pass Valve Setting-PSI: None
Beta Ratio: 2/20=24/44
Burst Pressure-PSI: 390
Max Flow Rate: 28-30 GPM
Nominal Micron Rating: 32
Gasket Diameters
Number O.D. I.D. Thk.
Attached 3.967 3.587 0.340
Get a dedicated bypass filter. Install it and visually verify the flow to the upper end. You can add tons of capacity to the sump with big enough bypass filters.
