Originally Posted By: PT1
Originally Posted By: boraticus
Fuel injection meters the fuel more precisely when responding to varying engine demands. With a carburetor, when a full throttle application is applied, excess fuel will be provided and likely not thoroughly burned. With EFI, the fuel is measured much more accurately to meet the load/demand that the engine requires. It pretty much provides better fuel economy and likely better power delivery for fuel burnt. Not sure if I'd go as far to say that more power will result from fuel injection. Just a better match for fuel delivered to meet power required.
You have obviously never tuned and re-mapped a fuel injected bike. You can actually increase the volumetric efficiency and air/fuel ratio of each cylinder. So more air & fuel in and out equals more power. With a carb you can re-jet but that is a close as you can get.
This was the question asked:
"Do you not get less fuel dilution with the run-of-the-mill fuel injection system? Better fuel economy? A bit more horsepower?"
I don't believe he asked anything about mapping.
