Quote:
the way Molakule is throwing out half-spoken accusations, without giving more info about it.
I am just giggling about the claims made as they are essentially the same claims made by Z-MAX and others.
As an educator as well, I try to get people to think critically about claims based on physics and chemistry. If I irritate you into thinking critcially, then I have accomplised my mission.
Most people would say I am "Overspoken" at times, certainly not "half-spoken."
I have asked these questions many times and have had no answers from anyone on:
1. how does a chemical "work harden" a metal surface,
2. how does a chemical "diffuse" into the metal; think crystalline structure of host metallurgy verses what it takes to diffuse anything into a closely-packed crytalline structure.
I laugh because I see no chemical or physical (aka physics) explanations as to how this could happen.
You have to realize marketing departments work overtime to get you to buy a product.
Does it reduce friction; it may but what is the real physio-chemical-material explanation behind it? Forget the marketing hype and half-baked marketing explanations.
Does it reduce friction via the use of chlorinated paraffins?
And if so, what is the corrosion and acid potential?
Does it reduce friction via the use of normal fatty acids or esters?
What are these new physio-chemical laws these people discovered that those of us in the industry have not found?
Just some points to ponder.
Please go ahead and use these products if you like. No one is keeping you from purchasing these products.
