I'm with Gary and Jason. Sample at 5K, and base the next step on that sample. Also, double up and send in a virgin sample with it (from the same batch if possible). That gives you the best "snapshot" both taken with Blackstone's "camera" so you can make an apples to apples evaluation.
Either way, IMO, reduce your idling (me, I would eliminate it... better a block heater on a timer).
Odd report (at least for this untrained observer). The lead was fairly high. So was the viscosity, but the insolubles were normal. High viscosity-low insolubles... usually a thickened oil has high insolubles, doesn't it?
