Originally Posted By: shpankey
Yea I had already looked at rockauto also. That's just some kind of connector thingy, not the PCV. But the Chilton's manual I have for the car says it does have a PCV valve on it, I will look for it tonight on the engine. But GM dealer and 2 autoparts stores said that there wasn't one.
btw I have my own ODBII and ABS scanner tool... I think it allows me to delete a code and make it never come back. I think.
I have this engine in my 1997 grand am. Although there is no pcv valve, there is an oil/water separator tank that sits under the intake manifold. The hose that comes out of the timing chain cover goes into it, and a hose comes out of this tank and goes into that big intake box.
Im actually having an issue with mine as we speak... every winter i get a lot of moisture that accumulates in the crank case, and doesn't disappear until the weather warms up. Last winter it happened because my pcv hoses were clogged with that frothy oil/water mix. Tomorrow im taking the hoses off again to see if that is again the case. Last year they got so clogged that my oil dipstick blew out because of the pressure. i make lots of longer trips so my engine is at operating temperature most of the time, yet the moisture is still there. could my separator tank be possibly clogged? my dipstick hasn't blown out yet this winter, yet it was raised up about an inch the other night after i drove the car... i'm thinking clogged hoses again.
oh and for the record, my car is making starts in zero degree F weather with no problem with the GC!
