Originally Posted By: crinkles
your load also has to be spread 60% in front of the trailer axle and 40% tot he rear.
That can't be achieved. The tongue weight limit for the Corolla's hitch is 200 lbs. Using your ratio with an 800 motorcycle would put roughly 500 lbs of weight in front of the trailer axle. That would far exceed the 200 lb tongue weight limit of the hitch. Besides with a FWD vehicle like the Corolla, you don't want to be taking weight off the front wheels, so my aim is to load the bike on the trailer so I end up with about 100 lbs of tongue weight.
no, you got it wrong. the 60%/40% DOES NOT mean the 60% goes onto the tow hitch!!!
now concentrate.
say the trailer weighs 1000 lbs.
Assume there is 10 feet between the tow hitch and the trailer axle.
the sum of the tow hitch load and axle load must be 1000 lbs, right.
the centre of gravity on a 60%/40% load spread may be say 1 foot in front of the trailer axle.
think about lever arms now. consider them about the trailer axle.
the 1000 lbs through the centre of gravity at 1 ft, must equal the tow hitch downforce times the distance from the trailer axle 10 feet away. therefore, 1000 ft-lbs need to be applied by the tow hitch relative to the trailer axle.
if it is 10 feet away from the trailer axle, it only needs to be 100 lbs (1000 ft-lbs / 10 ft) to maintain equilibrium.
remember, the trailer axle will support 90% of the weight with a 60%/40% spread to the front BECAUSE the centre of gravity is only slightly forward of the trailer axle.
loading a trailer with the centre of gravity behind the axle WILL MAKE IT SWAY!
You're right. I wasn't taking into consideration the law of the lever. The 60/40 thing shouldn't be a problem.
now concentrate.
