Found out that most 18-20 HP OPE engines with pressure lube are running 8-10 psi....sound about right?
if your talking engine oil pressure? no,,my INTEK 18.5 is putting out 50psi cold and 30ish warm.
Interesting..that's a good amount of pressure.
1.) A lot of pressure to move through the very small B&S oil filter?
2.) The pure-1 flows better than a Fram 2x which is a B&S Yellow.
Using the Pure-1 "tall" is not unreasonable with a 10W-30 RP Synthetic?
yea it's good some pressure i was surprised,thats why i went to the over sized P1.
here's my thread/link talking about my gage install and pressures on my tractor.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1578360
Nice set-up..10W-30 and a P-1 which flows very well vs. most frams even...ought be fine.
I would imagine that a big 20HP V-twin might be pushing hard against a tiny Yellow Briggs Filter?
