My brother bought his Sebring a few years ago used. He's not mechanically incline and was very hard on his old car, as far as routine maintenance. Since getting his Sebring (which just clocked 100,000 miles) he's just taken it to quick lubes for cheap conventional oil changes (and had a few bad experiences!) I first saw a couple months ago a post about the sludging issue the 2.7l v6 engines have, which got me worried. He had a slight oil leak and I put in a bottle of Auto-Rx I had in in hopes of curing the leak and break down any sludge that might be in there. There's no paper work about maintenance prior to him buying it so that has me a bit uneasy.
I just got a set of new ramps and am now able to change his oil for him (doing 3k mile or 3 month OCI). I've been reading up the last few days about the 2.7l and what red flags to look for, so along with the oil change I'll clean the PCV hoses and replace the PCV valve. Once the oil is drained I'll look in the oil filler and maybe take the valve covers off to see for myself if he has any sludge(hopefully not, but if so, probably will drop the oil pan as well to see just how bad.)
That leads me to my question, I plan to use a Motorcraft filter (since they're PureOne/Purolator Premium filters) and was thinking about putting in either Rotella conventional 10w-30 or Rotella T Synthetic 5w-40. My thoughts are that the detergents in the Rotella will help clean up the engine after the Auto-Rx cycle. I'm leaning towards the 5w-40 synthetic since I've read a lot of people say to run synthetic in this particular engine. Would the 40 weight be fine or should I stick to 30 weight? I've begun using Chevron Supreme conventional in my 2006 4.2l F-150, as I've read it's a great conventional. I figured I'd run at least a couple OCI's in my brother's car with the HDEO and either stay with that or then switch the Chevron Supreme.
Any comments or insight is greatly appreciated.
