I knew some guys that worked at a "junk yard" a local parts yard. This was the best parts place around, they didn't hand junk off to you, the mileage was written clearly on every motor, transmission etc, and you could walk the yard to pick your own stuff out. On the motors, I went to buy a motor for a truck I was working on, they always turned them over by hand, so he pulled the low mileage motor off the huge storage shelf (shelves were about 30' high, with holding spaces every 4' up or so) long story short the motor was seized up. I asked him if they had a lot of problems with this, he tried to twist a spark plug, he then said yes we have a big problem with people not spraying the cylinders down.. I was young then, and he was nice enough to explain that if you did not spray/fog the cylinders down 90% of the engines would freeze up/lock down/seize up whatever you want to call it... He also explained that low mileage motors out of new cars no matter what maker, aluminum, heads etc would do it faster than high mileage motors.. he even said he thinks it was due to no oil in the cylinders because they were still new-ish.
Glazed cylinders, aluminum heads, or aluminum engines make no difference on the rings freezing to the cylinder wall or whatever happens, I had a air cooled B&S and the motor was still new on a digger that froze up, and I pulled it apart cross hatches still on cylinder wall, top of aluminum piston still new with no carbon buildup, this was an aluminum block, aluminum piston, aluminum head, and it froze. I soaked it with several penetrating oils, heated the piston up and broke it loose easy.
Just a long winded wandering post, however if I were to store an engine over 1 month I would fog the cylinders, and if I did not fog the cylinders, stored the car for a couple months, and it seized I would be heart broken.. never forgiven myself if that were to happen.
