Further to this, ABS systems are another reason to change fluid more often, especially if you DIY.
The ABS systems, accumulators, lines etc... all hold brake fluid. Dealers have diagnostic equipment which can operate these valves and pumps to purge these "stale" loops of fluid when they're flushed. Does your dealer actually bother to do this, or pocket the extra money in time saved? A lot of people don't know for sure.
If your dealer is of this persuasion, or you DIY and don't have this diagnostic computer at all, your ABS system only circulates when ABS is activated. For me this is virtually never.
If your vehicle's max interval is 3 years, and you DIY at 3 years, you haven't changed any fluid in the ABS loop. If you change at 1 year and your ABS activates from time to time, or you go out in slippery conditions specifically to activate it, all of your fluid is, on average, fresher even in the areas that almost never circulate in the ABS system. Everybody wins.
