This is out of an old IH S1900 truck we run on our farm. The truck is in pretty rough shape, the cab mounts are all rotted out to the point that I believe the firewall is resting on the breather tube for the engine. While driving you can see the right front tire as there is a big hole in the floor. I think the voltmeter and speedo are the only gauges that still work. I did an in-frame on the engine 5 or 6 years ago as the cylinder liners were cavitated and coolant was getting in the oil. The truck itself was in much better shape back then. The truck has a little better than 10,000 hours on it. The oil was Texaco Ursa Super Plus 15w-40 and had about 360 hours on it. Not a bad oil report though.
Al 2
Chr 0
Fe 12
Cu 17
Pb 5
Tin 1
Moly 66
Ni 0
Mang 0
Sil 0
Tit 0
Pot 2
Bor 115
Sil 3
Sod 5
Ca 2248
Mag 222
Ph 979
Zn 1224
Ba 0
SUS Vis 74
Cst Vis 14.01
Flash Pt 425
Fuel % Antifreeze 0
Water 0
Insol .4
Al 2
Chr 0
Fe 12
Cu 17
Pb 5
Tin 1
Moly 66
Ni 0
Mang 0
Sil 0
Tit 0
Pot 2
Bor 115
Sil 3
Sod 5
Ca 2248
Mag 222
Ph 979
Zn 1224
Ba 0
SUS Vis 74
Cst Vis 14.01
Flash Pt 425
Fuel % Antifreeze 0
Water 0
Insol .4
