Ive been using m1 10w30 for 100,000 miles on a one ton dodge van 318 v8 , it weighs 5600 lbs, and i usually carry another 2000 to 3000 lbs a week in it carrying freight. It does not burn oil, never changes levels on the stick between oc, i run it 10,000 miles between ocs. I now have 200,000 on the engine and still no problems, i only get 14.85 mpg because of the wgt and one ton vans aren't good on mileage anyway. I don't add any additives to the oil or to the transmission. I do add stabil to the gas to clean out the fuel lines and carb due to the corrosion caused by ethanol gas, thats it. oh, by... the way this is a 2002 model, throttle body,,ancient technology,,but it works
