I just bought a 1997 Land Cruiser (80 Series) with 200k and I want to change all the fluids. AFAIK, the vehicle has always been run on dealer-fill bulk dino lubes.
-Engine: I will use Shell Rotella T 5W40
-Diffs: Calls for Hypoid gear oil API GL-5
-T case: Calls for Hypoid gear oil API GL-5
-Auto trans: Calls for ATF DEXRON®II
What would you guys suggest for the diffs, T case and trans? Should I stick with dino stuff or go with a nice synthetic? Is changing to synthetic after 13 years and 200k a bad idea. Leaks are not wlecome here
Cost isn't a concern, I just want to find the most suitable products.
Thanks
Thanks
