Well, you may have read my previous post when I was trying to decide between Fuchs Titan 5000 Dexron II and Titan 6000 Dexron VI. http://www.bobistheoilguy.com/forums/ubb...842#Post1713842
Well, asking in several shops about them, and also about the Gulf fully synthetic (also Dexron II), I found out that in every shop that sell either of them, the fully synthetic Dexron II versions are always the most expensive ones, even over the same brand's Dexron VI versions. Also, in both cases, (Gulf and Fuchs) these versions are recommended for heavy duty use.
That leads me to believe they are great ATF's, but then everybody advise to forget about Dexron II and go with Dexron III or VI, so I don't know what to do.
Then in pages like this: http://widman.biz/Seleccion/Reductores/ATF/atf.html I read sentences like "each Dexron generation has improved oxidation and acid-formation resistance, that's why choosing of Dexron II is not recommended in any case"
Or:
"Dexron II is way to viscous at cold temperatures, reducing transmission efficiency":
Then you go to check the -40ºC Brookfield viscosity of three kinds of Gulf oils and this is what you get:
Gulf fully synthetic Dexron II: 7700
Gulf fully synthetic Dexron VI: 11500
Gulf mineral Dexron II: 17900
Or the flashpoint temperature:
Gulf fully synthetic Dexron II: 246 º C
Gulf fully synthetic Dexron VI: 200 º C
Gulf mineral Dexron II: 184 º C
So I still don't understand it. These fully synthetic Dexron II are the most expensive ATF's and (at least in the case of Gulf, Fuchs TDS's are not as detailed) they exceed their Dexron VI and III "brothers", but most of the people I've talked with and the websites I read, told me to stay away from Dexron II.
Link to opieoils, you can see a list of ATF's ordered from the cheapest from the most expensive ones, in page II, you'll see the two most expensive Dexron II:
http://www.opieoils.co.uk/c-442-atfs.aspx?pagenum=1
Or:
