Originally Posted By: The Critic
Originally Posted By: oilcoholic
Waiting on the Rockauto shipment. I went tonight and got the CRC Disc Brake Quiet,
Do NOT use disc brake quiet on the Thermoquiets. They have a built-in insulator. These pads MUST be installed dry.
Wagner Thermoquiet pads have a built-in insulator. It's essentially pad material that is molded onto a metal backing plate. These pads must be installed dry.
Here's some documentation from the Federal-Mogul Tech Center. Look on page 12:
http://www.centralpartsandsupply.com/specials_flyers/Brake noise & repair.pdf
"Wagner ThermoQuiet, with its patented IMI Sound Insulator design, requires that
NO chemical compounds (EMP, Silicone Lubricants, Moly Lube, etc.) be placed on the insulator area of the disc brake pads. ThermoQuiet with the IMI Insulator is designed to be installed right out of the box and onto the vehicle. Use of chemicals on the insulator may reduce the insulator’s effectiveness."
Originally Posted By: sayjac
We bought/supplied the Honda OE pads, which comes with pads, shims and sauce packet, all together. Not disputing anyone here just adding an FYI.
The Honda pads include Molykote77, which is a lubricant, not a disc-brake quiet type product. Honda wants it applied to both sides of the shims and on the backing plate.
Originally Posted By: Char Baby
Elaborate! Are you sure? I use Permatex silicone brake lube on every brake job that I do regardless of the kind of brakes(semi-metalic, Ceramic etc.) And yes, I use it on the backs of the pads(non firction side)
It is okay to use a silicone/synthetic/moly-based brake grease on the back of most shimmed pads. Now, whether or not it is needed is up for debate. However, using
anything on the back of Wagner ThermoQuiet pads may cause problems.
Originally Posted By: mechtech2
It won't hurt to add additional anti squeal sauce to pads with shims. How could it? And why be so positive when warning about this? I am not saying it is necessary, but it won't hurt.
One thing: when you add sauce to a pad, install it right away and mash the pedal before it dries. Let the parts seat metal to metal, not with a dried rubbery coating in between [it will eventually seat in, but is not good procedure]. Get both sides at the same time, and you won't pop a piston out when you mash the pedal.
As the Federal Mogul document states, it may cause the insulator to be less effective. On some pads with riveted shims, it may cause the shim to separate from the backing plate.
