Honda GX35 question
by dirtydannyd
07/25/16 02:08 AM
Need advices for oil filter inspection
by ST2008
07/25/16 01:45 AM
Supertech- ST3387- Virgin cut open
by FordBroncoVWJeta
07/25/16 01:06 AM
Clean battery with garden hose?
by SavagePatch
07/24/16 11:55 PM
Toyota 5w20 blend?
by researcher
07/24/16 11:36 PM
Smoked some baby backs today
by BeerCan
07/24/16 10:28 PM
Ford FWD axle replacement
by 2009Edge
07/24/16 10:27 PM
Saturn ac compressor
by spasm3
07/24/16 10:20 PM
looking for spray guns - analysis paralysis
by tomcat27
07/24/16 10:18 PM
WIX 51372 ADBV Failure
by WellOiled
07/24/16 10:11 PM
moly + engine coatings
by benjy
07/24/16 09:57 PM
Worth the upgrade?
by daves87rs
07/24/16 09:47 PM
curiousaboutoil, 01CAMRY, corndogzombie, NJ1911, SneakyTacos
58587 Registered Users
58 registered (AlienBug, aquariuscsm, B320i, 2009Edge, Astro14, Al, 5 invisible), 1200 Guests and 11 Spiders online.
58587 Members
66 Forums
252222 Topics
Page 1 of 2 1 2 >
#1739683 - 01/11/10 08:44 PM "service vehicle soon" light won't go away
Pluto5 Offline
Loc: Virginia
After service facility changed oil and coolant on my 03 Impala the "service vehicle soon" light came on. I returned the car and they could not find a problem and cleared the computer. Now the light comes on after driving about an hour at high speed. What kinds of problems is this light supposed to indicate? I am not referring to the check engine light.
#1739686 - 01/11/10 08:47 PM Re: "service vehicle soon" light won't go away [Re: Pluto5]
Big_Kat Offline
Loc: Iowa
Look in your owners manual to see if its just a mile counter...
2011 Jeep Compass 8000 mile OCI
Where would life be without mutations?
#1739691 - 01/11/10 08:51 PM Re: "service vehicle soon" light won't go away [Re: Big_Kat]
Pluto5 Offline
Loc: Virginia
I checked the owners manual and it says that the light will come on if you have engine problems. It further states that the problems may not be obvious and may not affect performance or durability. Don't know what to make of that. There is no obvious problem.
#1739701 - 01/11/10 08:57 PM Re: "service vehicle soon" light won't go away [Re: Pluto5]
JHZR2 Offline
Loc: New Jersey
What was the code?
#1739710 - 01/11/10 09:04 PM Re: "service vehicle soon" light won't go away [Re: JHZR2]
SLCraig Offline
Loc: London, ON, Canada
Probably something like gas cap or something lame like that.
Lots of little things can trigger check engine lights.
You need a scanner... They're inexpensive, and give you a good idea of what you're dealing with, even if you're a virgin working on cars.
2010 Civic SI sedan 6MT
SynPower 5w30 | Fram Ultra | Pennzoil MTF
#1739756 - 01/11/10 09:28 PM Re: "service vehicle soon" light won't go away [Re: Pluto5]
mechanicx Offline
Loc: Ohio
Did you reset your OLM? I think service vehicle soon is a body control module code and not everyone can pull those codes.
Edited by mechanicx (01/11/10 09:38 PM)
Edit Reason: typo
#1739770 - 01/11/10 09:34 PM Re: "service vehicle soon" light won't go away [Re: Pluto5]
crazyoildude Offline
Loc: New Jersey
Do you have a scanner? If so scan it if not have someone else that knows do it
Will Not Use Oil Filters With Those Tiny Restrictive Looking Louvers! Also Not A Fan Of Oil Jugs That Don't Have A Security Inner Seal..
#1739772 - 01/11/10 09:35 PM Re: "service vehicle soon" light won't go away [Re: mechanicx]
MrHorspwer Offline
Loc: Michigan
"Service Vehicle Soon" does not equal "Service Engine Soon". An SES light is an OBD2 emissions concern; a SVS light (or message) is typically a non-OBD2 powertrain DTC or a body DTC. If it is a body DTC, your local AutoZone isn't going to have the capability to read the DTC. You will likely need a Tech 2.
Shot in the dark here... make sure all your exterior lamps and DRLs are functioning. Are you having any problems with the fuel gauge? Tire pressure low or mismatched tire sizes? Anything going on inside the car: courtesy lamps not illuminating, power door locks not functioning properly, etc.?
edit: Just saw that you had your coolent serviced. Make sure the coolent level is properly topped off in the resevior. If it has a pressurized coolant tank, give it a couple sharp taps. Sometimes the level sensor gets stuck at the bottom when the coolant is drained.
Edited by MrHorspwer (01/11/10 09:37 PM)
#1739775 - 01/11/10 09:38 PM Re: "service vehicle soon" light won't go away [Re: MrHorspwer]
mechanicx Offline
Loc: Ohio
sorry I meant sevice vehicle soon is BCM not service engine soon. I mistyped that. I agree with you.
#1739792 - 01/11/10 09:55 PM Re: "service vehicle soon" light won't go away [Re: mechanicx]
JimPghPA Offline
Loc: Pittsburgh,PA U.S.A.
If you figure out what caused the code please post any resolution you find for this problem.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
#1740463 - 01/12/10 01:17 PM Re: "service vehicle soon" light won't go away [Re: JimPghPA]
eljefino Offline
Loc: ME
It's a non-emissions solenoid controlled by the PCM or BCM. I bet they yanked a wire during the service. frown
Probably an accessory like cruise control lost contact with the main computer. There will be a code and I bet they're ducking the issue. At least squeeze the code out of them.
#1740565 - 01/12/10 02:55 PM Re: "service vehicle soon" light won't go away [Re: JimPghPA]
mechtech2 Offline
Loc: Chicago Area
Some parts stores like auto zone will read your trouble coeds for free. Make some calls and drive to one that does.
#1740715 - 01/12/10 05:45 PM Re: "service vehicle soon" light won't go away [Re: mechtech2]
PT1 Offline
Loc: near the mistake
Take the car to your dealer if your "service facilty" is not a dealer. Let them see if there are any codes and do the reset. BTW, don't go back to that "service facility" because they don't know Mr. J. Schitt.
Edited by PT1 (01/12/10 05:46 PM)
Oils well that ends well...
#1740837 - 01/12/10 07:12 PM Re: "service vehicle soon" light won't go away [Re: PT1]
CROWNVIC4LIFE Offline
Loc: Miami-Dade County
My dealer [Pompano Ford] charges 100 bucks to check codes...The Autozone nearby does it for free...It all depends who is working that day when you come show up.
Thats why their called Stealerships.
05 Ford Crown Vic
5W20 Motorcraft Full Synthetic
Bosh D3410 Filter
07 Merc Grand Marquis
Motorcraft Filter.
#1740847 - 01/12/10 07:16 PM Re: "service vehicle soon" light won't go away [Re: CROWNVIC4LIFE]
Andrew MKZ Offline
Loc: USA
my light came on and it was because some [censored] at the GM dealer didn't know how to put a hose on correctly after some basic work.
2010 Lincoln MKZ
23,500 miles
Formerly DT466E_bus
Page 1 of 2 1 2 >
