Originally Posted By: mechtech2
You think you don't get 'deflection' with an impact gun and socket?
Are you kidding? You'll get more with all that dancing around!
Gotta disagree this time mechtech2. Impact guns, when used properly, are VERY easy on the nuts, bolts, and studs they're being used on. You are FAR less likely to break a rusty stud trying to remove a nut from it with a properly sized impact wrench (don't use your lug impact on exhaust studs, of course). The reason is that the repeated sharp hammer blows take advantage of the mass of the stud itself. The socket hammers the nut and tries to turn it very quickly relative to the stud, and the stud's inertia helps prevent it from twisting. If you just put a breaker bar on there and gradually start increasing the torque, the stud sees the FULL torque you apply and will more likely break.
Likewise with tightening, the stud doesn't take all the twisting torque- its inertia moderates the force it has to see. Plus of course you NEVER run up to full torque with an impact- you just "snug" things and finish with a torque wrench.
Can you break studs with an impact wrench... sure, if you set the air pressure to max, grab the trigger, and have a cup of coffee. But don't do that!
