OK apparently I have an exceptional lawn tractor!!!
I have a 2006 John Deere LA135
http://www.deere.com/en_US/ProductCatalo...&link=enav#
22hp briggs v twin with the 46" snow blade
http://www.deere.com/en_US/ProductCatalog/HO/attachments_flash/rle/index.html?att_num=BG20020. it is a hydro automatic too! This is my 3rd winter with it and I have few if any problems plowing!! Including ramming large piles of snow, you have to do that to move the larger piles!! Yes if you inch up to them and then try to move them you will start to spin the tires as the snow weighs more than you and the tractor. DUH!?
Last year after a blizzard made 3 foot drifts in our street and since we live on a secondary street and needed to get out before the snow plows got here I helped plow out the street in front of our house and our neighbors kids where also there with shovels helping also, but me and the Deere was doing most of it and the neighbors where very happy that after I did my driveway I wheeled into the street to start plowing it. Good thing we only live on a 1 block long street.
This December has set a record for snowfall here at nearly 25 inches in just 2 blizzards, one being over Christmas. I have plowed my driveway and two of my elderly neighbors driveways since their plow service was "TOO" busy to get to them right away. After the Christmas snow I had a drift that was taller than the Deere over my driveway and I also had to plow the 1st snow's snow into the middle of my yard to make room for the new snow. I now have piles of snow about 4 feet high in my yard and will be adding to that before it is all over since none of it is melting as the temps are very cold this year. I do have tire chains but I do not have the wheel weights, I am a LARGE man and have more than enough extra weight. It takes a little work yes but I do just fine!!!
Occasionally I can get stuck if I try to get a little to much in a hurry and I have had to get off it twice now to lift the back end and move it over out of a large pile so the chains could get a better grip. It gets high centered. I get mad at having to man handle it but I have no one to blame but me for getting in a hurry so I deal with it. Like I said I am large enough to do it so not really a big deal to lift it and move it over a foot or so if needed.
Other than that I can't complain one bit sure beats a shovel and a sore back!!! And spending hours bent over shoveling!!!
It is 15 below this morning with another 6 - 7 inches of snow forecasted to fall on Wed then winds to drift it again on Thurs with a morning low of 20 below and 5 below high temp on Friday!! Sure I'll be cold but I'll be done plowing with my Deere faster than using a shovel!!!
BTW I use Amsoil in it and I have no problem starting it either and it sets out in the cold not a garaged baby either, biggest problem is the cover likes to freeze onto the hood and makes it hard to get it off.
So I am confused and amazed that I seem to have a "super" lawn tractor compared to most everyone here. Plowing snow in the winter in addition to mowing in the summer (DUEL USE) is how I was able to talk my wife into spending the money on a Deere and not some sears special.
My biggest complaint is some peeling paint and some rusting but since it sets outside all the time that is problem I am sure. So I keep an eye on it and use oil based implement enamel every time I see a paint problem. Genuine Deere green of course!!
I also have the CargO Mount electric spreader unit that hangs on the back of it behind the seat. It holds 100lbs of fertilizer or seed in the summer and I also use it in the winter to spread deicer after I plow. I would not try salt as it can be too big sometimes and may clog it. But deicer works just fine.
NOW the snow blower attachment would be useful and I am considering maybe getting it my self if it keeps mega snowing like it has this winter
http://www.deere.com/en_US/ProductCatalo...20480&tM=HO
It would be nice not have to tear up my grass plowing snow into the yard to make room for more snow as the blower would be able to blow it far into the yard and I think it could be a time saver not having to keep ramming the large piles over and over to move them along to where you need them. But for now I have my Deere and a blade!
