Originally Posted By: Jason2007
So is this the Peak Global that is sold at WalMart/Kmart???
No I don't think Walmart sells Peak Global. Walmart, like most places, sells Peak extended life and Prestone extended life, both of which are believed to be dexcool. Also Peak long life that other stores carry is most likely dexcool. If you want the non-dexcool formula, you have to get Peak Global, Professional or Final Charge.
Cavaliers aren't known to have problems with Dexcool. They have a pressurized reservoir and compatible gaskets.
