I've got a Pajero/Montero with V4AW3 tranny.
It was originally filled with the ATF Diamond SP3 (equivalent).
In the last revision i did, the mechanic identified the level of ATF was low and completed the level with about 2.5 liters of Dexron II compatible oil.
The MMC recommends the Dexron II for this tranny (no problem with that), but, as it was previusly filled with SP3 ATF, so my question is: is there any problem mixing SP3 ATF with Dexron II ATF ?
Thanks
Thanks
