Originally Posted By: JHZR2
The question is why... does anything truly state that the maxlife is an acceptable spec for the audi tiptronic? If they are not, most will not sacrifice a $$$$ AT for a few dollars saved on fluid.
Given that some folks actualy care about what happens after 150k miles, the right fluid also makes a difference.
So again, wh does a "simple" AT service cost $350 minimum? Is the tiptronic fluid $$$?
There always is a driving factor, the question is why. If maxlie could be used beynd reasonable doubt and the service was simple, it would not be a $350 service.
http://store.europarts-sd.com/MaxLife_ATF_Letter.pdf
http://www.blauparts.com/vw/vw_fluid/vw_automatic_transmission_fluid.shtml
Our Vw automatic transmission fluid is at a great discounted price for every Vw model! The HIGHEST quality performance Vw automatic transmission fluid, that meets necessary specs! Only from the nations leading independent Vw Fluid Specialist, BLAUfergnugen! Inc.*
How to change your Vw automatic transmission fluid isn't as difficult as you think. Flushing your Vw automatic transmission fluid is easier because our years of Vw transmission repair service experience can be helpful to you! BLAUfergnugen! explains how to change Vw automatic transmission fluid.
As an independent Vw service garage, we know what fails on Vw's and why. Changing your fluids is the single most important preventive maintenance and yet for many Vw owners seems to be the most neglected area! Flushing your fluids at the proper intervals can get your Vw to 150,000 miles and beyond! Vw automatic transmission fluid should be changed every 30,000 miles (heavy city) - 60,000 (highway) (see technical info below). Changing your Vw automatic transmission fluid helps extend the life of your transmission by properly lubricating the main shaft bearings and synchros. This is most easily done in conjunction with the Vw transmission filter maintenance.
Some vehicle factory manuals suggest Dexron III Vw automatic transmission fluid, others recommend Vw automatic transmission fluid meeting Audi Vw specification TL52162 (Audi Vw part number G 052 162 A2). It seems that publications began to indicate changes in fluid recommendation with vehicles manufactured in 1995. Starting around 2001 semi-synthetic Vw part number G 052 990 A2 automatic transmission fluid started being used in 09A series transverse mounted 5 speed tiptronic Vw transmissions. Around 2002 Pentosin G 052 182 A2 fluid was used in 6 speed models with direct shift automatic gearbox (DSG) double clutch transmissions code 02E. All customers should check there Vw owners manual or Vw factory service manual for what ATF is recommended for use in their vehicle. Starting in 2005 Vw 09G series 6 speed transmissions (non DSG) used G 055 025 A2 ATF.
Vw Automatic Transmission Fluid - Pentosin G 052 162 A2
Vw Automatic Transmission Fluid - Mobil Dex III
Vw Automatic Transmission Fluid - Febi Bilstein G 052 990 A2
Vw Automatic Transmission Fluid - Pentosin G 052 182 A2
Vw Automatic Transmission Fluid - Fuchs G 055 025 A2
Vw Manual Transmission Fluid (a.k.a. Gear Lube)
Vw Automatic Transmission Filter Kit
Vw Automatic Transmission Fluid VAG 1924 Tool Replacement
Vw Automatic Transmission Fluid Information:
Why do we say that changing the Vw automatic transmission fluid (ATF) extends the life of your transmission? We've witnessed in our own service facility what regular transmission fluid maintenance can do. The biggest difference we've seen is the elimination of shift problems in Vw tiptronic transmissions due to old transmission fluid and filter. Remember, you should always change the Vw automatic transmission filter every time you do a fluid change. Why contaminate clean fluid with the sediment that is stored in an old automatic transmission filter (see illustration below).
• Why changing your Vw automatic transmission fluid (ATF) is important.
• Changing Vw automatic transmission fluid used to be difficult.
• How to change and flush Vw automatic transmission fluid (ATF)
