I have several older small machine tools that have bearings, shafts and a few gears. The old manuals usually call for SAE 30 oil. The machines are old and were built before detergent oil existed. Conventional wisdom says to use non-detergent oil in these machines because detergent oil will hold debris in solution. These machines don't have combustion chambers so there's no combustion byproducts to end up in solution and I don't think detergent oil will hold metal particles in solution. I have a couple of questions.
1. Is there any good reason not to use detergent oil in these small old machines? This is sort of an academic question since I have non detergent machine oil on hand, I would just like to understand the non-detergent oil requirement.
2. I've been told that detergent oil is more hydroscopic than non-detergent and will pick up moisture which will in turn cause foaming and lubrication failure. Is this true? Is detergent oil actually more hydroscopic than non-detergent and if so, is it really a problem? These machines don't get hot enough to drive off significant moisture.
Appreciate comments and answers.
Thanks,
Bob
Thanks,
Bob
