Originally Posted By: rcy
The new Equinox has a pressurized 'surge' tank with the rad cap on the tank instead of the rad. This is a new design to me - all other vehicles I've owned having a coolant overflow bottle that was not pressurized.
What's the reasoning behind this type of system? Is it to prevent Dex-Cool from reacting with air?
Its a fairly old design now- Jeep Cherokees had it in the 80s, my wife's 93 Vision TSi had that design.
It works well, really minimizes evaporative loss from the cooling system, minimizes air exchange (keeps oxygen out). It also circulates coolant through that tank constantly, unlike "open" systems where the tank only gets a squirt of excess coolant as the engine heats up and then draws a small squirt back into the engine as it cools down. Open systems also quit exchanging coolant with the overflow bottle AT ALL if there's a small leak high in the system which lets air intrude rather than sucking coolant back from the overflow- which means that open systems have a failure mode where the overflow tank level is right but the radiator is actually very low.
The downside is that when that plastic tank goes "bang" and splits open under pressure, you're stuck until you can get another one. Early Jeep Cherokee owners (for example) consider it a reliability upgrade to convert to an "open" conventional overflow tank system used on later Cherokees. That said, wife's 93 made it to >250k miles without having the tank fail. But it was looking REALLY yellow brittle when we got rid of the car. If we'd kept it, I'd have replaced that tank before taking it out of the city limits. Overall, I prefer the open system because I'm a maintenance freak and check the ACTUAL level in the radiator regularly. But for the "I turn the key and it goes" crowd, the pressurized reservoir is probably a little safer (assuming they ever look at it at all).
Yes, it does work better with DexCool too because it minimizes oxygen intake into the cooling system, but the design itself pre-dates DexCool by 10+ years.
