Subject minivan (not really mini are they but maybe they are talking about the space under the hood to work) is running hot according to the gauge on the instrument cluster. The vehicle (belonging to sister-in-law) has 150k miles. They have left it for us to fix over the weekend while they visit family a few states away. According to records from the previous owner, the coolant, water pump, & intake manifold gaskets were all replaced at 100k miles give or take a few thousand. I have no way of knowing what kind of coolant was used then but I assume Dexcool. At any rate, the first drain, including overflow, (lower radiator hose removal since petcock is broken) looked like muddy Tennessee river water after a heavy rain. The cooling fan does kick on but it doesn't drop the temperature to normal. No fluid is pulled from the overflow even when the radiator is low & the overflow reservoir is full. The hose between the overflow & radiator is open.
He (father-in-law) changed the radiator cap to 16# (OEM is 15#). No help.
We have replaced the thermostat (no record of that happening) which helped somewhat. Prior to this, the upper hose wouldn't get very hot but it will now.
We have run 3-gal of distilled water through the system. We poured directly into the radiator where the cap screws on with the lower hose removed until clean. We poured directly into the radiator where the upper hose connects until clean (lower hose removed as well). It seems this would indicate that the radiator isn't plugged, right? We have filled the radiator & run the van for a while & drained that. We are only able to pour 1-gal max at a time to fill as this is all that comes out. That flush was not running clean yet, but we have quit for the day & will finish the flushing in the morning.
It is still running hot. What else can we do? If the water pump impellers were shot, it wouldn't push the coolant through the system but that pump supposedly only has ~50k miles on it & the upper hose is now getting hot. The temperature sensor doesn't seem like it would be bad since the gauge is working & responding in a reasonable time frame.
I don't have a coolant system pressure tester. Head gasket?
Thanks for the help.
