Originally Posted By: mechanicx
What has the Ford 302 really proved? Most of the stock ones scarcely have valves or ports any bigger than the 305's. The Ford 302 just isn't a torguey engine IMO. I'm not arguing that the 302 doesn't work or since its received so much attention has been made into something. Sure all those things that you mention matter, but what sense does it make to have 4x3 bpre/stroke, then run short rods and small cams, ports and valves because all you are looking for is low speed torque? You can't stroke the Ford 302 much either.
1987 302 (HO, SEFI):
225 HP@ 4800
300 TQ@ 3200
1987 305 (HO, TPI):
215 HP@ 4400
295 TQ@ 3200
1987 350 (TPI):
225 HP@ 4400
330 TQ@ 2800
The 302 made MORE torque than the 305, at the SAME RPM. And it managed to still make 10 more HP.
The 350 matched the HP of the 302, but at a lower RPM. And made more torque (and I would hope it would with 48 extra cubes).
The 302 had a broader power band (just looking at the numbers) and yet with all this talk about square, over-square, under-square, made MORE torque than this fabled "torque monster" 305.
The 302 can be stroked (in the stock block) to 347ci. Aftermarket blocks (like the R block I posted earlier) can be stroked beyond 360ci.
If one wants more displacement, you can then go to the 351W, which will do 427ci.
Or we can not compare the worst year/ratings for the Camaro engines to the best rating of the Ford Mustangs:
1991 was also the first year that Z28 Camaros equipped with the 305 TPI motor and a manual transmission had the same roller cam profile as the 350 TPI motor. Power ratings on the 350 TPI were as follows;
250 hp (186 kW) at 4400 rpm and 345 lb·ft (468 N·m) at 3200 rpm. Power rating on the
305 TPI motor were as follows; 235 hp (175 kW) at 4200 rpm and 300 lb·ft (407 N·m) @3200 rpm. Rumors say that these numbers were slightly underrated by GM, but this has not been investigated.
Keep in mind these are just factory Peak HP and Torque ratings and do not really address the overall torque curves.
For the Mustang I couldn't find good ratings handy for the '91 5.0, but seems it was overrated by then anyway as many Chevy guys and some disgruntled Mustang owners have claimed through the 90's and Fords seemed to acknowledged by '93.
Quote:
For 1987, the Mustang received E7TE heads and a more capable intake manifold. The E7 cylinder heads were sourced from the truck line after the 1986 swirl-port design demonstrated performance problems. Power ratings jumped to
225 hp (168 kW) and 300 ft·lbf (410 N·m) of torque. With the end of the run near in 1993, Ford switched to cast hypereutectic pistons for all 302 cu in (4.9 L) engines and also re-rated the
5.0 GT at 205 hp (153 kW) and 275 ft·lbf (373 N·m) of torque. This estimate was more accurate because the previous power ratings were made before the addition of the mass air flow system, a minor revision in the cam, and other various changes.
So to highlight,
1991 305 (TPI):
235 HP@ 4200
300 TQ@ 3200 (possbly underrated as GM was known to do)
1991 350 (TPI):
250 HP@ 4400
345 TQ@ 3200
1991 302 (HO, SEFI):
225 HP@ 4800
300 TQ@ 3200
Possibly overrated as has been claimed about Ford by some during the time period and perhaps closer to this:
205 HP
275 TQ
Anyway I think I'm going to drop out of this thread since the inaccurate/unfair comparisons never seem to quit coming. I'll say this though. When you see Ford guys' arguments then why they are Ford guys in the first place starts to make sense
