On my 2005 Toy 4Runner I have replaced the original tires with Yokohama Geolander H/T-S P265/65R17 110S tires. They are the recommended tire size.
The sidewall: 51 Max PSI. Toyota manual and dealership recommend 32 PSI. (Why? for a softer ride?) I think that is under-inflated for these tires.
I compromised and get slightly better mileage at 40 PSI but Toyota dealer claims that would eventually wear out the center tread, though I'm concerned (but not overly) that at 32PSI is under-inflated and would hurt the sidewalls?
What PSI would you recommend? And is inflating any tire at its max PSI (51 in my case) too high?
Thanks.
Thanks.
