I've always heard of "break-in" oil in engines when they come out of the factory. Is the idea of "break-in" true? If it is, how is the formulation different?
And you could change it every 5-7.5K miles and still get to the 100K miles without any problem.quote:
I changed it every 3-4k miles during the 100k miles I had it and never had a problem.
I am not so sure about this. A couple of years ago I picked up a certified Civic Si with 3145 miles on it ... from a Honda dealership. They had changed the oil.quote:
True for Honda. It is NOT the typical "motor oil" you drain out after 3-5,000 miles. It is quite obvious it ain't the stuff you buy at Autozone.
I did not leave it in for 5,000 miles, either. Sorry, but there is no way I can do that on a new engine, even a Honda.
Then how come so many new engines continue to use oil up to the 2K mark?quote:
many automakers now run new engines on a dyno prior to being installed in the automobile
