Originally Posted By: addyguy
The oil pan is attached to the block - it should warm up as well, if the heater is left on for a reasonable amount of time.
It's attached to the block with a gasket, which will insulate it. Plus most pans are steel, which is very poor at conducting heat. The oil temps will barely be affected.
