Oh I guess there is one of those 40 microners in there. Thanks ThirdEye! Your on top of it! I'll make a note of it on the results page.
Originally Posted By: Craddosk
Sounds interesting! Though, wouldn't the cloud of dust require "somewhat" consistent dispersal of the dust, and a set amount of dust? Maybe a set amount of dust on the filter, being pulled through by the vaccuum and gravity, if the dust cloud can be emulated. Can't wait to see it!
Indeed. I will probably have to have the test filter in between two boxes of some sort.
I am thinking in general right now to weight the dust with my reloading powder scale and blow it into the airstream with a venturi device from an air compressor. This is how they do it in SAE tests, IIRC.
The hard part will be capturing the dust that makes it through in a even-handed and meaningful way.
I may try comparing color variation on an oiled back-up filter to catch the pass-through dust, and I may see about a weighing a small vacuum cleaner style HEPA filter before and after to see what it collects after the filter under test.
I have some research to do first.
