Good evening all,
I've been experiencing a few issues with my 2001 Saturn SL w/ 109,080 miles on it. For the past few months, my engine sometimes will stay stuck @ 2,200rpm idle rather than the normal 800rpm. This happens when I come to a stop but will also happen if I'm coasting with the clutch to the floor. I first figured it was just the throttle position sensor going on me.
However, some folks at saturnfans.com recommended I check for an intake manifold gasket issues (which is a somewhat common failure for the Saturn SOHC of my model year engine).
I finally got a chance to check it out today but like a good BITOGer I checked my oil before I went to get brake cleaner to check for an intake gasket problem.
My oil was 1/2qt low and I noticed white streaks on the stick even though the oil has ~400 miles on it. I don't think it is moisture, because I drove 20 miles highway the night before on my way home from work at 70mph. I wiped the dipstick clean and checked the oil ~8 times with streaks each time. Eventually I didn't get any more white streaks but I suppose I may have disturbed the oil surface in the pan.
I checked my coolant reservoir tank to make sure I wasn't getting oil into the coolant and that I didn't crack my cylinder head. Cylinder head crackings are another issue with these SOHC engines.
Here are some pictures. It started snowing and blowing wind so I didn't get a chance to check my IM gasket.
(Pictures are large in size, but I wanted folks to be able to zoom in and get a closer look.) If you look closely you will notice the white streaks.
Oil
Coolant Resevoir
My cheapest option to check for coolant would be a UOA. However, I used Mobil Clean 5000 two oil changes ago. The oil after that was Formula Shell and now it again has Formula Shell in it. I have heard it takes a few OCI to purge any residual sodium from the add pack of Mobil Clean.
The M.O I am considering is dumping this oil at 3,000 miles, then doing ~1,500 miles on another fill and draining that out for a UOA. I figure after 3 oil changes any sodium would be ridden from the engine.
Let me know what you experts think.
Thanks in advance.
Oil
Coolant Resevoir
Thanks in advance.
