I could not word my title correctly, so here it goes.
Last winter I stored my car in a 45 degree garage and had to sometimes move the car outside to pull another in to work on it. After doing this a few times my oil got cloudy from the quick starts not getting the oil temp up. So I changed the oil in the middle of winter and never started it again.
This year I am not so lucky, I had to rent a storage unit that is not in any way heated. I want to pull the battery and never start it. I was advised to not do that unless I remove the spark plugs and fog the cylinders. I am not going to do that for the reason the 4.6L's have inherent thread problems with plugs ejecting. So I assume I will need to start it every month or two and need to know how long it will need to idle to warm the oil enough to not cause moisture.
BTW, I am running PP, and it was the brand of oil that got cloudy last year.
