I am a newbie on this site and I don't know all of the acronyms yet so take it easy on me. I have a '06 2006 Z06 Corvette with the LS-7 motor. I am looking for an oil that will withstand the higher temperatures that I'm seeing on the track but still be OK on the street. So here are the details;
- I live in Northern Calif and almost never see freezing temps.
- I have about 20,000 miles on the car and about 25% is on road race tracks.
- I drive to and from the tracks and also do some occasional street driving. My miles are about 1/3 track and 2/3 street.
- The GM recommended oil is M1 5W30 and I have been using that until the last oil change when I switched to M1 10W30.
- My oil temps while racing are typically 230F TO 260F. At a few events with high ambients, I have seen temps as high as 290F.
- The stock LS-7 motor runs some pretty high oil pressures but at the end of a hot track session the idle pressure can be as low as 10-15 psi. A check that I do at the end of each session is to record the oil pressure at 3,000 RPM. With oil temps of 240F I 'm seeing oil pressures of 41 psi.
- The LS-7 has a 8 qt. dry sump system that is susceptible to pressure losses in long hi-G sweepers. I have added an additional 3-qt. (for a total of 11 qts.)capacity to the tank to help mitigate this.
- I race about every 6 weeks on average and have been changing the oil about every 3 races. A typical race day is 4-5 25 minute sessions spread through the day.
- I sent an oil sample off to Blackstone a while back but have not got the results back yet.
So my question is should I consider a higher weight oil or a racing oil? I am worried about the higher temperatures and the need to still get good oil pressures to help at the 6,500-7,000 RPM shift points. These are some of the oils that I have been thinking about;
- Mobil 1 0W40 European Formula
- Mobil 1 0W30 Racing oil
- Amsoil 0W30 SSO (what is SSO?)
- Amsoil 10W30 ATM (what is ATM?)
- Amsoil 10W40
- Redline 30W Race oil
- Redline 40W Race oil
- What do you suggest?
Thanks in advance,
John
