Originally Posted By: rpn453
How is something in FRONT of the MAF and TB going to take away low-end power?
That part of the intake affects the tuning too. The engineers who design the OEM intakes don't make them as small as they do because they're too stupid to realize that bigger is always better.
Interestingly enough, replacing the stock intake tubing on my Mustang did nothing to reduce low-end power, but did increase top-end power.
The engineers have to deal with intake tract NOISE. The reason my Expedition has TWO silencers in the intake tract sure isn't to help with low-end torque production. Both of which are smaller than the factory throttle body.
Removal of these two devices make for an increase in power under full load above 4,000RPM. With no loss of low-end power. It also got MUCH MUCH MUCH louder. The butt-dyno is often confused.
Quote:
For lower levels of power output, where most people drive most of the time, the OEM design will often provide more torque and better fuel economy.
Air modulation is performed by the throttle body. This is the last component before the intake. You are trying to tell me that the size of the tubing BEFORE this variable restriction is in some way going to affect how this device functions? The biggest restriction at the "drive around town" power level and throttle position IS the throttle body.
Quote:
Of course, the OEM design also incorporates noise reduction, so that may offset the benefits of the smaller diameter intake.
Noise reduction is likely the primary role. You restrict the tract, and make it smooth, and you reduce noise. The fluted airbox breather and the smoothed and reduced diameter throttle body feed tube on my Expedition both do a significant job of reducing noise. An impressive job actually. Removing them increased the under-throttle noise of the engine several-fold.
Quote:
Check out the dyno graphs on the K&N website, and you'll find that many, if not most, only show the results above 3500 rpm.
If the factory air system is not adequately able to feed the engine above 3,500RPM under full load, then logic would dictate that replacing it with a freer flowing system would increase power in that area......
Quote:
Every design involves compromise, and a CAI usually compromises low-end torque, fuel economy, noise reduction, and filtration efficiency for peak power gains.
Perhaps using the term AFTERMARKET CAI would be more accurate. Most manufacturers utilize some sort of factory cold air induction system. Every vehicle I've ever owned has been factory piped to breath air that comes from outside the engine bay.
Quote:
Fly-by-night companies may make fuel economy claims about their intakes because they have nothing to lose, but K&N makes no claims that its products increase fuel economy:
Originally Posted By: K&N
A lot of exaggerated claims are made in the marketplace by products claiming to improve gas mileage. K&N makes no general fuel economy claims, however we encourage you to try our air filter for yourself. Keeping air filter restriction as low as possible can be an important tool, among others, for maintaining high mileage. For more info read what some of our users have to say on the K&N testimonials page.
http://www.knfilters.com/filtercharger.htm
I wouldn't expect a fuel economy gain either. And would ONLY expect a power gain if the factory system was at some point in the engine's power band, a restriction.
