Here is a recommendation from Corvette Forum on breaking in a newly rebuilt motor. Any comments?
I never heard of "Joe Gibbs Break in oil" ?
"Don't switch to synthetic for at least 2500 miles. With your high tension rings, the synthetic will immediately stop ALL break in. But the organic oil will continue to allow the rings to seat.
Running regular oil will cost you about 10rwhp on the dyno, but I have seen it a million times. The guy switches to synthetic, then begins complaining he has oil consumption and/or blow by. Alot of times this is because he switches over to a synthetic based oil to soon.
Seriously, as an engine builder, it is not something we EVER reccomend. There is 100 different theories on how to seat the rings. But when it comes to oil use, safe is ALWAYS better.
After about 2500 miles, then, and only then, switch to synthetic.
Our recommended break-in is as follows:
* Joe Gibbs Break in oil 10/30 with high ZDDP, and filter for 30 minutes. Then change filter.
* Change oil/Filter again at 2 hours, or 150 miles
* Joe Gibbs break in oil with high ZDDP and new filter for additional 250 miles. Then change oil/filter
* Regular 10/30 and good filter for additional 2000 miles. At 2000 miles, check your oil consumption. if you are fine, then switch to synthetic. If not, run hard to 3000 miles. Then swap to synthetic regardless.
This is our required break in for our customers motors.
OE rings, OE replacements, and a lot of the low tension rings have extremely fast break in periods. But the moly steel rings don't break in that easy."
