Ok, I've searched but still would like an opinion.
1999 Jeep Cherokee 4.0L. Iron block and head, probably aluminum radiator, aluminum freeze plugs. It's been 3 years since I flushed and refilled the cooling system, and at the time I used Prestone AM-AM extended life which still has a green color. Until recently, I figured green is green so I didn't think twice about it. Now I understand that Prestone is NOT the typical green silicate that was factory, and that it is more closely related to Dexcool. I'm debating weather I should A) Continue using Presetone universal B) Refill with Zerex "Green" C) Go to G-05 since this was what Jeep/DC started using in 2001. There is some sediment present in the radiator neck so I will be flushing no matter what fluid I install. I really hate doing cooling system maintenance, so an extended life coolant is highly desirable. It's such a nasty job and a pain to recycle the old stuff plus all the contaminated rinse water that has to be collected.
By the way. The factory service manual only specifies ethylene glycol based coolant with Alugard 340-2.
Thanks.
Thanks.
