Originally Posted By: The Critic
Originally Posted By: Saturn_Fan
Originally Posted By: bruno
Only caution I've heard about them is to keep pressure below 10 psig .
Brake fluid reservoirs aren't made to take pressure !
Thanks for the tip! I believe they are gauged at 0-30 psig, so I'll definitely keep her in the lower 1/3 of the scale.
Thanks!
I have one and I use on my SL2. Make sure you get both the universal adapter and the GM specific adapter. The universal adapter is a pain to use, but it's necessary for Toyotas, Hondas and a few other cars. On your Saturn, just use the GM specific adapter-- it'll screw right onto the master cylinder.
I disagree with keeping the pressure below 10 psi. You need to pump it up to 15-20 psi. This will ensure a proper bleed. With the Motive unit, I can pressure bleed all 4 corners in under 10 minutes.
Before you start bleeding, be sure to pump the pedal between 5-10 time until it's stiff. Also, during the bleed, lightly tap the calipers or wheel cylinders with a rubber mallet to dislodge the loose air bubbles.
What's the theory behind pumping the brakes a few times Mike? Is it to get the pistons pushed all the way out in the calipers before you begin bleeding? If so, why is that helpful?
