I've seen these "high performance" radiator caps, that are a high pressure than standard caps. They claim you should run the highest pressure cap that your radiator is able to withstand. I guess the theory is high pressure allows a higher boiling point which transfers heat better?? I don't know, I did two searches and could not find any info.
Any truth to this stuff?
