What grease for a sqeeking garage door??
Superbuick96
Site Donor 2023
Cleveland, OH
I believe the horrible sound coming from the garage door is coming from the track where the wheels roll up and down.. I tried spray lubricates with no luck, Im guessing the proper grease would do the job. Being a newer home owner, and never previously having a garage, what kind of grease should I buy to quiet down this door? Thanks for the suggestions
Garage door Grease from Ace hardware. Comes in a tube. Spray is ok but the good stuff is in a squeezeable tube.
you may want to check the wheels that run in the track. They do need to be replaced at times.
