Originally Posted By: chevrofreak
NOTHING I have done has made a significant impact on my oil consumption. MMO, Auto RX, High Mileage oils, I was still using oil pretty darned fast. If I can make it 2,500 miles without adding a quart, I'll be impressed.
I have been reading your posts and I had a thought, have you checked your whole PCV System, meaning the Breather and PCV Valve, as well as the PCV Baffle in your valve covers, I think you said it was leaking fresh oil.
On my small block chevy I had put in a Push In Chrome Breahter cap, I developed some fesh oil leaks, I checked my breather and it had some oil in it, so I put back on the old style breather with a pipe extension, now my breather does not get saturated with oil and there are no more leaks.
Your problem sounds like a PCV issue, JMO.
