Originally Posted By: swalve
If I remember from what I read, there will always be a touch of drag if they are set up right. Something about the geometry of the shoe, drum and the pivot points.
Not true. The auto-adjusters will adjust the shoes to within 3-click-of-the-auto-adjuster away from a slight drag, at least that is the way it has been with every automobile I have ever owned. Twice a year, at seasonal tire change time, I will tighten the adjusters two or three clicks till the shoes almost drag. It minimizes wear on the star wheel and adjustment lever to manually adjust.
Someone had mentioned that auto adjusters rarely work. It is true that they are seized on a lot of cars. If kept clean and lubed they work very well. I have never had a seized adjuster on any vehicle under my care.
