I'm looking for suggestions on what could be wrong with my car. Let me describe the symptoms for you.
Any ideas?
- If the car has been sitting in the cold for a while, the car will crank fine, but it fires up slowly. Like it wants stall. This also happens if I disconnect and reconnect the battery.
If I turn the ignition to "on" and pump the gas pedal a few times it starts up fine. Pumping the gas pedal once doesn't work, I have to pump it like 7-8 times.
- Lastly, I'm getting bad gas milage. On 87 octane it seems to be worse than on 91. And no it's not just in my head, I compared data to back it up. 18 MPG on 87 octane and 20 MPG on 91 octane. The car was designed to run on 87 octane, and my engine is completely stock.
Any ideas?
