Oil Temperature dipstick?
How about using an infrared thermometer? It will read the temperature of any part of the engine you aim it at. That's what I use when tuning my old air cooled Yamaha RDs.
Chances are that your crank case/transmission will be very close to the same temperature as the oil.
Thanks for the help.
I guess that will have to do til I get the temp gauge working.
Just don't want to ride til I make sure it is not running hot!
Just changed the oil over to Shell Rottela, next I will clean and service the cooling system.
