Originally Posted By: ADFD1
Just out of curiosity how is the Chrysler 3.7L they use in some of the Jeeps?
Structurally, its a 4.7 SOHC v8 (iron block, chain timed) with two cylinders removed. The Chrysler 4.7 and Ford Modular 4.6 are *very* similar in basic architecture, so the Chrysler 3.7 is also more like a Modular than the 3.5 (2nd gen) all aluminum engine.
HOEWVER, the problem with the 3.7 is that like the Buick 3.8 and Chevy 4.3 Vortec, its a 90-degree block. The crank pins are splayed, but only partially because that was the best compromise between smoothness and crank strength. That leaves the 3.7 a slightly odd-firing design. Fine for truck use, but not the best for high RPM or sustained high power operation. The 3.5 is a fully even-firing 60-degree engine, like the Chrysler 3.8 used in the Jeep Wrangler for example (also an iron block nearly indestructable engine- but again more tailored for truck use than high performance.)
The draw of the SOHC 3.5 HO engine for the Charger Police Package is raw power with light weight and better efficiency. A 3.5L Charger will beat a 4.6L CVPI in both top speed and acceleration. The downside is its got a shorter fuse- its just not a 400k mile engine. Of course the 5.7 Hemi is also available, and it *should* more or less match the 4.6 for longevity- iron block, forged crank, chain timed, etc. The jury's still out because its just not old enough to trickle down to taxi fleets yet. I do have to wonder why they were so determined to beat the CVPI with their lower-option police car, which they freely admit was aimed at city patrols. I guess it does provide a more "dual duty" car for departments that want it. A lower-powered engine like the 3.8 or 3.7 already mentioned should be fine for patrol work- leave the high-speed tire-smoking screaming to the 5.7 version.
