So I added a cooler to the Pontiac Montana. 4T65E. Its all metal pipe except for a small section in the middle. What I did was cut the hose and spliced in the cooler there. I thought it was 5/16" hose because the transmission hose I had left over from another project was the same O/D. Could not find any markings. Well, it must be 3/8" because now it pours out of the fittings like it was made to do that. Should I up grade to 3/8" stuff all the way, which will invalidate all the fittings I just bought, and the hose, or just buy 3/8" to 5/16" adapter.
