Good evening fellow BITOGERS
I want to use PP in my 2008 Impala with the 3.5L Flex-Fuel V-6.
I've used the Chevron 5W-30 dino with great results. It, along with PYB are my two favorite dinos. I like the thin 9.7 cst @ 100C viscosity of Chevron. I presume it probably has an HT/HS of 2.9 which is the minimum allowed for an oil to be called 5W-30.
I know the PP 5W-30 is 10.3cst @100c. I would like to blend it with PP 5W-20 (2/3 10.3 + 1/3 8.48) to get approx. 9.7.
I know that the 5W-30 has GM4718M & HTO-06 certifications for Corvette and Acura.
Do you think the 5W-20 is as sheer stable and deposit resistant even though it has not been certified as such (since Corvette, although I have heard that will change in the next couple of years, and Acura do not spec the 5W-20 oils in their performance applications)?
I think that oil for oil, Mobil1 5W-20 is more stable than 5W-30 and Mobil1 EP 5W-20 is even more stable than their 5W-30 counterpart, etc. or is that not necessarily true due to blending differences, such as the 5W-30 having, say, more PAO in the mix?
Any insight would be appreciated, and yes I know that running PP 5W-30 would be fine as well.
Thanks,
Gary
Thanks,
Gary
