I have a mower that lists the spindle grease as: US Lithium MP White Grease 2125, with the following listed as compatible greases:
Mobilix #2 found at Mobil Service Stations
Ronex MP found at Exxon Service Stations
Super Lube MEP #2 & Super Stay-M #2 found at Conoco Stations
Shell Alvania #2 found at Shell Service Stations
Lidok EP #2 found at industrial shops
Timken Lithium Multi-Use #2 found at industrial shops
I can't find any of these products locally. After an internet search, I can't even find any information on US Lithium MP White Grease 2125.
Does anyone know anything about US Lithium MP White Grease 2125, such as the manufacturer? What would be a good substitute that is available at most auto parts stores? The spindle uses tapered roller bearings. Is an EP grease required? The local auto parts stores have the full line of Valvoline greases, Castrol Pyroplex Blue, Mobil 1 and Mystik JT-6.
Thanks for your help.
