I just drained the factory fill oil in my 2009 Aura 2.4 ecotec and replaced with mobil 1 and purolator pure one filter.
Anyhow... the manual says it takes 5 quarts including filter so after I let it thoroughly drain on a flat surface and replaced the filter I put in 5 quarts.
Out of habit I checked the oil level on the vehicle and found it to be probably 1/3 inch past the 'max' hash mark or roughly 1/3 the distance min and max past the max mark.
Is this enough of an issue to where I should drain some oil out and if so how much oil should I try to drain? Would my car likely give some sort of indicator light if the oil pressure was too high?
Surely if I drained it completely on a flat surface it couldn't have held more than, say half a quart meaning it's got 10% too much oil... would that be a problem?
BTW, I am pushing the dipstick all the way in when I check the oil, to the point where the gasket is seated. I'm pretty sure that's what I'm supposed to be doing but in case it's not I guess that could explain why it's showing up a bit too full.
Thanks
Thanks
