http://www.bobistheoilguy.com/forums/ubbthreads.php?
ubb=showflat&Number=1540233&Searchpage=2&Main=111687&Words=corvette&Search=true#Post1540233
German Castrol, 0W-30, 2974 miles, 1999 Corvette
Curious_George
Loc: Lake Mary, Florida 1999 Corvette, LS-1 5.7L 346 CI V-8 (2nd Sample)
MI/HR on Oil - 2,974 miles
MI/HR on Unit - 85,573
Sample Date - 10/26/08
Make Up Oil Added - 0 qts.
2nd Sample / 1st Sample / Unit (Engine) Averages / Universal Avg.
ALUMINUM - 2 / 4 / 3 / 4
CHROMIUM - 1 / 1 / 1 / 1
IRON - 10 / 15 / 13 / 15
COPPER - 4 / 5 / 5 / 35
LEAD - 4 / 13 / 9 / 7
TIN - 2 / 0 / 1 / 2
MOLYBDENUM - 4 / 12 / 8 / 64
NICKEL - 0 / 1 / 1 / 1
MANGANESE - 0 / 1 / 1 / 3
SILVER - 0 / 0 / 0 / 0
TITANIUM - 0 / 0 / 0 / 0
POTASSIUM- 2 / 2 / 2 / 1
BORON - 5 / 15 / 10 / 68
SILICON - 6 / 8 / 7 / 10
SODIUM - 5 / 7 / 6 / 7
CALCIUM - 1739 / 1800 / 1770 / 2354
MAGNESIUM - 513 / 430 / 472 / 269
PHOSPHORUS - 820 / 797 / 809 / 743
ZINC - 1035 / 1014 / 1025 / 892
BARIUM - 0 / 0 / 0 / 0
2nd Sample / 1st Sample / Nominal
cSt Viscosity @ 100°C - 64,6 / 64.1 / 59~68
SUS Viscosity @ 210°F - 11.51 / 11.35 / 9.9~12.7
Flashpoint in °F - 410 / 390 / > 385
Fuel % - < 0.5 / < 0.5 / < 2.0
Antifreeze % - 0.0 / 0.0
Water % - 0.0 / 0.0 / < 0.1
Insolubles% - 0.2 / 0.4 / < 0.6
NICK: Great recovery in lead accumulation! We thought that the high lead discovered last time was due to
something temporary, and the shorter time on the oil went far to bring lead down nicely. This shows that
bearings wore more agreeably on this oil's watch, and that's good. Other metals were low and well
balanced, so no new problems at parts were evident. In fact, nothing unusual was noted among wear metals
this time. Physically, the oil looked great. Insolubles were low, showing limited oil oxidation and no
combustion issues.
Check back to build wear trends.
http://www.bobistheoilguy.com/forums/ubb...rue#Post1431424
Raced 94 Corvette LT1-RedLine 10w-40 2200 miles
sidney004
Loc: Castro Valley,CA Car has 72,200 hard driven miles.It is taken to road race events, this sample represents 13 hours of track use(4200 RPM to 6000RPM at 280F+) The data is listed from newest sample on the left to progressively older data. First data set(Rl 10w-40),second data set(RL 10w40),third data set (RL 10w-40),fourth data set (RL 10w-30), fifth data set(Amsoil 10w-30 + red bottle Valvoline Synpower), sixth data set(Amsoil 5w-30) Amsol EAO23 filter was carried over from last two changes(8000 miles total), changed out for next cycle. Air filter changed from foam to paper.
FE 26.....33.....30.....49.....36.....94
CR 2......3......2......2......2......5
NI 2......3......2......5......7......18
AL 16.....16.....9......13.....9......34
PB 25.....35.....25.....58.....39.....111
CU 8......8......7......7......7......15
SN 23.....23.....6......15.....6......21
SI 45.....81.....34.....18.....16.....30
B 23.....41.....20.....28.....136....3
NA 37.....33.....32.....37.....16.....28
K MO 965....908....726....695....231....11
P 1056...1145...1049...1303...1348...1309
ZN 1509...1564...1170...1803...1589...1968
CA 3417...3502...2633...3605...2796...3554
MG 28.....30.....27.....254....837....427
Miles 2200...2000...3800...3000...3100...6000
Fuel T/S% H20 VIS 14.5...14.3...16.3...12.1...13.5...12.8
Interesting how the Al, Cu and Sn are identical to the last batch, what a coincidence!
http://www.bobistheoilguy.com/forums/ubb...rue#Post1306952
_______________________
Here are the latest oil analysis results from my 98 Corvette
Analysis by Wearcheck Canada
5800 miles on oil
Nov 14 to July 18 (8 months)
106,000 miles on the car
Pennzoil Platinum 5w30
NAPA Nascar oil filter
Vararam cold air kit (with a cotton gauze filter)
LS1 5.7L V8 engine
7 qt oil capacity
1.5 qts of makeup oil added
Oil life monitor was at 12%
Iron 18
Lead 3
Aluminum 12
Copper 1
Chromium 2
Tin 1
Silver 0
Titanium 0
Nickel 0
Silicon 11
Potassium 0
Sodium 0
Boron 38
Barium 0
Vanadium 0
Manganese 1
Sulfur 2301
Calcium 3257
Magnesium 19
Moly 57
Phosphorus 763
Zinc 909
Oxidation 69
Nitration 53
Sulfation 57
*note, the above three values are not percentages*
ZDDP 17.5
Viscosity at 40c 58.7
Viscosity at 100c 10.9
Viscosity Index 180
I changed the oil earlier than I had planned (I always wait for the oil life monitor to hit zero) because my Fram Sure Drain plug system was starting to leak oil and messing up my garage floor. Luckily I had a spare new one to replace it.
I refilled the crankcase with Pennzoil Platinum 5w30 again, but this time I am using the Fram Extended Guard oil filter.
http://www.bobistheoilguy.com/forums/ubb...rue#Post1456702
http://www.bobistheoilguy.com/forums/ubb...rue#Post1288511
Elevated iron:
Royal Purple 10W40, '96 LT4 Vette, 3,150 miles
Michael SR
Loc: Houston, TX i forget the exact total mileage on the engine, it's roughly 30,000 miles. this was about a 6 month interval, about 12 auto-xes, some romps in between. RP was not by choice, just happened to be on the shelf at the shop when i resealed the intake manifold (note high silicon).
the engine has a GM "HOT" cam, longtube headers, and some WOT tuning (a touch leaner), but is otherwise stock.
amsoil oil filter. half a quart of makeup oil, about 1000 miles prior to draining. (the TBN is still unbelievable, even given the makeup oil.)
Al 8
Chr 2
Fe 54
Cu 7
Pb 12
Sn 1
Moly 61
Ni 1
Potassium 12
Boron 4
Silicon 65
Sodium 10
Calcium 3046
Magnesium 367
Phos 847
Zinc 1204
Barium 11
TBN 9.3
SUS 74.0
Flashpoint 355
Fuel 0.8%
Coolant & Water 0.0%
Insolubles 0.2%
blackstone's comments: Considering this engine sees harder wear than most of the engines in our average file, we think yours is wearing quite well. We did find a little bit of fuel dilution, which is common in engines that see a lot of idling and/or racing. Note silicon, probably from sealers or an additive.
i'd appreciate any and all comments and analyses. thanks.
http://www.bobistheoilguy.com/forums/ubb...true#Post232343
Loc: Houston, TX Here is some information on this engine. I changed the rod bearings right after draining this oil. The engine had ~2000 miles at this point, and had been beat hard in both racing and countless dyno runs. Given that the bearings were "bad," and that there were visible metal flakes in the oil i drained out, i'm really surprised at how good this report is. oh, and this is using a K&N 3002 oil filter.
Al 2Cr 1Fe 14Cu 28Pb 13Mo 40Mn 1K 2B 6Si 55Na 4Ca 3614Mg 101P 812Zn 957SUS 100C 65.8flash 395fuel
http://www.bobistheoilguy.com/forums/ubb...true#Post257171
02 Vette - GC - 2K miles - LS1 Engine
vettenuts
Loc: Rhode Island This should be fun.
I sent this sample to Terry for his interpretation and thought it would be worth some discussion here on BITOG. Here is the background, a little complicated, but here it goes. In the fall of 05 I installed a new cam, timing chain, rockers, pushrods with guide plates in my 02 Vette. Subsequent to the cam installation, I had the car dyno tuned where the parameters of the computer are updated for the new setup. Approximatley 1,000 miles later I did an oil change with GC and a Baldwin filter.
This spring, after planning all winter, I started the car after storage and drove it about 20 miles to make sure it was running good. I then put it back in the garage for major surgery again and then tore it down and installed new heads (these were brand new Dart heads so they included new valves, new guides, etc.) new lifters and new pushrods which needed to be shortened for the new lifters. The lifters were also packed with a grease that washed out in this batch of oil. The grease was black and I would suspect it had moly in it. I tried to rinse it out with oil by soaking the lifters and then rotating the roller while submerged in oil by hand. The manufacturer told me to use this procedure and not use a cleaner to do this as it might have the potential to start the motor with poorly lubricated rollers. I would guess that there was grease remaining in the lifters. The lifters were Morel's, if that helps at all. I spoke to Rick Morel before installing them to get his recommendations on preparation and followed them to a "T".
When I installed the heads, I drained the block of coolant as best I could, but there was some remaining coolant in the heads when I pulled them and it spilled. Not sure how much, if any, entered the motor but it may be the source of some of the coolant. I have not lost any coolant since the head change, at least not a measurable amount that is observed in the recovery tank. I have kept a close eye on it because of the new head gaskets. I also used Redline Assembly Lube during setup.
I also had to have the tuning in the computer changed after installing the heads. I had an issue when the car was on the dyno in that the K&N filter was clogged with pollen from all the pollen last spring. The dyno tune is the last step in the process, a street tune is done first to ensure all the fuel trims and timing is correct for normal street driving. The dyno is for WOT tuning and my tuner is very conservative with his tunes (not too lean). We cleaned the K&N with air and finished the tune on the dyno, but what we didn't realize at the time was his tuning for normal street driving was wrong because he calibrated the MAF with the clogged air filter. I then changed air filter setups and now run a system with the Green filter, but it is still an oiled filter. However, because the filter was clogged and the tune was done for street running with the clogged filter, when I put in the new Green filter the MAF was not correctly calibrated and I spent two months chasing a rich code that was turning on the check engine light. As part of my diagnosis, I also did an injector balance test. We found the problem and corrected the MAF calibration, no more rich codes since but there was almost two months of driving with this problem. Not sure if this accounts for the fuel but I did notice my tailpipes have cleaned up a bit after the fix was made. Fuel trims are now in the -2 to -6% range.
Hopefully, this explains some of the things you see in this analysis. Let me know if you have other questions. The car runs great, hasn't used any oil or coolant at all and seems to be functioning perfectly normal. So, what does the collective community think of this one?
2002 Corvette w/modified LS1
21,200 miles on car
2,190 miles on oil (oil was changed with this sample)
Iron 38
Copper 95
Tin 0
Lead 7
Chromium 8
Nickel 2
Aluminum 13
Titanium 0
Silver 0
Calcium 2,177
Magnesium 186
Zinc 997
Phosphorus 774
Barium 1
Molybdenum 12
Antimony 0
Silicon 46
Sodium 11
Boron 1
Potassium 0
Vanadium 0
Viscosity (40/100) 68.3/11.6
TAN 1.35
Flashpoint 360
Oxidation 16
Nitration 10
Water (KF-ppm)384
TBN 7.20
Fuel 219
Soot 0
Glycol/Coolant 2.027
Viscosity Index 165
Sulfate Byrproduct 21
http://www.bobistheoilguy.com/forums/ubb...rue#Post1565742
http://www.bobistheoilguy.com/forums/ubb...true#Post224193
