Originally Posted By: 01rangerxl
Originally Posted By: stranger706
Originally Posted By: Gary Allan
Quote:
How long do rotors last?
If they're designed (spec'd) correctly for the application ..and you drive like you believe that replacing them is something to be avoided, ..forever.
If you drive like the car is a mule doing a thoroughbred's job ..and that driving as fast as you can between braking events is something you're supposed to do ...not long at all.
I've yet to replace rotors on my wife's jeep in 90k. The only reason it's not the 140k on the odometer is due to having to have some specially machined to fit the Warn hub kit I installed (which is also a reason why I have good cause to avoid changing them now). On my jeep, the OEM are on their @ 80k. They needed to be turned due to my oldest daughter driving it for a good bit early on. Both have the OEM assembly line rear shoes.
No, this isn't some unicorn of automotive revelation. It just takes preemptive pad changes and sensible driving habits.
+1
My wifes Explorer just passed 93,000 miles with original pads and rotors. The pads have about 25% material left. Rotors look new.
My Mazda has 72,000 miles. Also original pads and rotors. Pads are less than 50% worn. Rotors look new.
Not sure what the big secret to long lasting brakes is. We've never lived in a big city, maybe thats it?
I live in a big city with bad traffic. You have to do a lot of stop and go driving here. Also, my truck tows, gets mud on the brakes, and it has me behind the wheel. I consider pads and rotors a regular replacement thing, and am just fine changing them every 80K.
Rear brakes are another matter. I haven't touched the drums on my truck. They are all original and in good shape.
At 80k miles,I'd probably clean and re-adjust the rear drum bakes.
