Good day everyone,
I was recommmended to post here. I'm hoping that you can enlighten me with my oil analysis from NPower (Cummins service).
According to NPower, my oil sample came back with high levels of Silicon & Sodium, but with no Glycol present. They are saying that it's a coolant leak. But wouldn't the test have to show Glycol also present? The engine uses HOAT glycol based coolant.
Also all of the other metals & Potassium levels were down from the last test 7500mile before.
They state that all engine wear rates are normal. Where Sodium level (oil additive/coolant) and silicon (coolant additive) are higher than typical or dirt present possibly gaining with the coolant.
I did the oil change where I found that my oil filter was not on as tight as I always tighten it. So there there was very light seepage that was going back towards the turbo propeled by the radiator fan. Since my boot on my inlet was not seated correctly do to the aftermarket TAG (air striaghtener) I leaked to the turbo inlet. I believe that is my source for the silicon.
As for the sodium, when I submitted my sample I told them it was standard Rotella T 15W40 when actually it was synthetic Rotella T 15W40.
Or do you think that the sodium & silicon levels be high from burning WMO blended with #2?
I'm kinda new to this analysis. From what I read about older diesel (pre-emission) was that the combination of silicon & sodium was considered dirt ingestion.
Any and all input would be great.
